shanmei
Advanced Member level 1
There are 10 pmos transistors with identical size, for example, 10um/5um . I would like to do the analog circuit layout, and match them well.
As shown in the figure, the red line is the n-guardring, which is connected to nwell; the blue line is the p-guradring, wihch is short to ground.
In Fig.1, each transistor is cycled by its own n and p guradring. The neiboring nwell should have a certain space requirement to meet the drc rule, so each block has to be placed far away, which is not space efficient.
In Fig.2, the total 10 transistors are shared only one n and p guardring.
Questions:
1. For Fig.2, is there a latchup issue since not every transistor has been cycled by the n and p guardring?
2. Which one is a good design?
Thanks.
