Plecto
Full Member level 5
Hi. I'm looking for a dual low quiescent current switching regulator, but theres a couple of things I don't quite understand with these regulators. Looking at the LTC3622 (http://cds.linear.com/docs/en/datasheet/3622fc.pdf); it has two modes it can go into if the ouput current is low enough, burst mode and pulse skipping mode. The datasheet states the following:
Does this mean that burst mode and pulse skipping mode is essentially the same, the difference being that burst mode has 12 times as high inductor current which leads to a higher output capacitor which again leads to longer time between bursts? Judging from the graphs below, both modes sends a bursts that increases the output voltage before going to sleep:
The datasheet states that the regulator will automatically switch from continous mode to either burst mode or pulse skipping mode if the output current is low enough, but if these modes are more efficient than continous mode, how come it doesn't run in these modes all the time? In continous mode, the pulse width is adjusted to match the current demand, but the efficiency of the regulator does not depend on the pulse width, right? Does this mean that running burst mode for as long as possible is always the most efficient?
Two discontinuous conduction modes (DCM) are available
to control the operation of the LTC3622 at low currents.
Both modes, Burst Mode operation and pulse-skipping
mode, automatically switch from continuous operation to
the selected mode when the load current is low.
To optimize efficiency, Burst Mode operation can be selected
by tying the MODE/SYNC pin to INTVCC. In Burst
Mode operation, the peak inductor current is set to be
at least 400mA, even if the output of the error amplifier
demands less. Thus, when the switcher is on at relatively
light output loads, FB voltage will rise and cause the ITH
voltage to drop. Once the ITH voltage drops low enough,the
switcher goes into sleep mode with both power switches off.
The switchers remain in this sleep state until the external
load pulls the output voltage below its regulation point.
When both channels are in sleep mode, the part draws an
ultralow 5µA of quiescent current from VIN.
To minimize VOUT ripple, pulse-skipping mode can be
selected by grounding the MODE/SYNC pin. In LTC3622,
pulse-skipping mode is implemented similarly to Burst
Mode operation with the peak inductor current set to be
at above 66mA. This results in lower ripple than in Burst
Mode operation with the trade-off being slightly lower
efficiency.
