blakes7
Newbie level 6
I recently complied a VHDL program for a 4-bit adder/subtractor using Xilinx ISE 14.7 and suddenly got the error message -
INTERNAL_ERROR:Xst:cmain.c:3464:1.56 -
Process will terminate.
For technical support on this issue, please open a WebCase with this project attached at https://www.xilinx.com/support.
I also got warning messages about a missing .stx file for the project.
I could not find anything wrong with the VHDL code.
I went to google and found the answer at the following URL -
What the above link says is -
From the main menu in Xilinx ISE 14.7 -
Project -> Cleanup Project Files…
Press 'ok'.
This made the error message go away and I could synthesize my VHDL code and produce a .BIT file. I also tested the design for the 4-bit adder/subtractor on the NEXYS-2 FPGA board.
Anyone else experience this with Xilinx ISE ?
If so I hope the above helps.
There is also a similar thread on this matter at -
https://www.edaboard.com/threads/260103/
Press 'ok'.
