It really depends on the simulation process which currently mainly includes initial simulation including the debugging and testing some basic test cases stage and the regression stage meaning a lot of testing cases are executed when there're rare errors. During the initial stage, which mainly requires the debugging the basic faults during the coding and some easily-found errors of the design, so that this stage will often use some linting stragety and the event-driven simulation methodlogy is utilized with Verilog-XL and VCS with linting options. After that, you'll test the design when there are rare errors will be found and then you can use cycle-driven simulation which means faster simulation performance when you can use NC-verilog of Cadence and VCS with some options.
It depends on Design as well
1) For Asnchronous Design(Networking , comuunications products ) Cadence Tools like NCverilog which is a Event Based Simulator is preferred
2) For SYnchonoua Designs ( Microprocesors ) , Synopsys tools VCS which is a cycle based SImulator is preferred
