+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 5
    Points: 1,253, Level: 8
    Join Date
    Dec 2008
    Posts
    10
    Points
    1,253
    Level
    8
    How to reduce EMI in analog IC pad design
    Hi all,
    I designed some I/O and passed ESD test. But customer asks me to lower rise/fall time of voltage output for reducing EMI. I donot know how to do with it . Firstly I think I can segment output driver of IO pad, but it seems it is not very useful.
    Can anybody show me how to do with pad design? Thank you very much. Or show me some paper, then I can refer it.
    •   Alt10th February 2012, 11:02
      advertising
  2. #2
    Advanced Member level 3
    Points: 7,253, Level: 20
    checkmate's Avatar
    Join Date
    Feb 2004
    Toilet Seat
    Posts
    833
    Points
    7,253
    Level
    20
    Re: How to reduce EMI in analog IC pad design
    You just need a weaker drive, ie lower W/L in output stage.
    Of course, the challenge is in dealing with the additional delay caused by longer rise/fall times.
    •   Alt10th February 2012, 13:08
      advertising
  3. #3
    Advanced Member level 5
    Points: 35,418, Level: 45
    Join Date
    Mar 2008
    USA
    Posts
    5,681
    Points
    35,418
    Level
    45
    Series gate resistance or an undersized predriver will give
    you a slew-rate-limited driver (Miller capacitance*dV/dt
    vs available gate drive). Controlling slew rate internally
    is better than using a weak driver and counting on load
    capacitance to limit voltage edge rate, less board level
    loading variability in timing.
    You can also segment and time-cascade the outputs if
    you have enough edge time allotted. Have seen LVDS
    drivers done this way. Be sure you segment them odd
    rather than even, or you'll get a "porch" right at the
    threshold when you'd rather step across it smartly.
    1 members found this post helpful.
    •   Alt10th February 2012, 17:22
      advertising
  4. #4
    Newbie level 5
    Join Date
    Dec 2008
    Posts
    10
    Points
    1,253
    Level
    8
    Thank you, Dick and checkmate, I will try your ideas.
