Bootstrapped switch Sample and Hold circuit - with dummy and without dummy
wandola
Junior Member level 3
Dear all,
I am designing a low-to-medium S/H circuit for an ADC. The sampling switch is a bootstrapped switch to linearize the on-resistance.
I first designed a bootstrapped switch, and I simulated the waveforms and obtained DFT and THD in cadence with the calculator.
After that, I also designed a dummy switch to cancel the charge-injection and clock feedthrough. I think the results is not bad.
I also obtained the new output DFT and THD. However, I found the DFT plot of the S/H output with and without dummy is almost the same. ( the 2nd harmonic, 3rd harmonic, magnituedes are almost the same)
But from the transient simulation results I can see the S/H with dummy actually has betteer accuracy.
Can anyone command on this?
You can see the three lines for Vin, Vout_no_dummy and Vout_withdummy, respectively.
I also attached the two DFT plot here.
It can be seen that the 2nd harmonic distortion for S/H with dummy is actually 1dB worse than without dummy.
Is it possbile that the DFT plot is not correct?
I did DFT with coherent sampling. Please take a look
In a first order, charge injection causes a fixed (or linearly voltage dependant) offset but only few non-linearity. Thus it doesn't show up in DFT. Adding the compensation FET can even add some non-linearity, as your measurement shows. Not surprizing in my opinion.
Thanks a lot man. I understand now.
That really helps.
