erfan.khalilian69
Member level 4
- Joined
- Feb 7, 2011
- Messages
- 71
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,288
- Location
- Kualalampur
- Activity points
- 1,916
Hi everyone
in my project I want to increasing the speed of dc motor according to the temperature , I have found some sample source I try to modified it but it does not working (simulated with Proteus)
here is the code :
#define alarm RC1 // activate as fan but I put led for this part
#define motor RC2//DC motor activate as fan
unsigned char speed=50;
//////////////////////SET PWM//////////////////////////////////////
CCP1CON = 0b00001100; //PWM Mode
PR2 = 0xFF; //PWM Period Setting//PWM frequecy set as 4.88KHz
T2CON = 0b00000101; //Timer2 On, prescale 4
CCPR1L=0;
f(temperature>27)// when the temperature goes above the 27 degree C the fan activated otherwise the fan is deactivated
alarm=1;
else if (temperature>30)
while(temperature>30)continue;
CCPR1L=speed; }
/* else if (temperature<27)
CCPR1L=0;
/*else if (temperature>35)
if(speed<255)speed+=1;
CCPR1L=speed; // INCREMENT THE SPEED OF MOTOR
delay(5000);
else if (temperature<35)
if(speed>0)speed-=1;
CCPR1L=speed; // DECREMENT THE SPEED OF MOTOR
delay(5000);
plzzzzzzzzzz help
actually while I write CCPR1L=0; then it does not work at all ? i dun know why ?
any advice ?
thanks everyone
---------- Post added at 20:39 ---------- Previous post was at 20:37 ----------
here is the main code which I have tried to modified it :
#define BUTTON1 RA1
#define BUTTON2 RA2
#define BUTTON3 RA3
#define BUTTON4 RA4
#define CCW RB1
#define CW RB2
// function prototype
void delay(unsigned long data);
// global variable
unsigned char temp=50;
// main function
void main(void)
ADCON1 = 0x06; //Configure Poart A as digital I/O
TRISA = 0b11111111; //Set pin RA1 to RA4 as input for press button switch
TRISB = 0b00000000; //Set pin RB1 & RB2 as output for MD10A
TRISC = 0b11000000; //Set pin RC2 as output for PWM
//Motor stop
CCPR1L = 0; //No PWM Duty Cycle
CW = 0;
CCW = 0;
while(1) //Infinity Loop
if(BUTTON1==0) //Brake
CCPR1L=0;
CW=0;
CCW=0;
else if(BUTTON2==0) //Change the Rotational Direction
while(BUTTON2==0)continue;
CCPR1L=temp;
CW=!CW;
CCW=!CW;
else if(BUTTON3==0) //Speed Increment
if(temp<255)temp+=1;
CCPR1L=temp;
delay(5000);
else if(BUTTON4==0) //Speed Decrement
if(temp>0)temp-=1;
CCPR1L=temp;
delay(5000);
here is the code :
CCPR1L=0;
alarm=1;
CCPR1L=speed; }
CCPR1L=0;
delay(5000);
delay(5000);
plzzzzzzzzzz help
any advice ?
thanks everyone
#define BUTTON1 RA1
#define BUTTON2 RA2
#define BUTTON3 RA3
#define BUTTON4 RA4
#define CCW RB1
#define CW RB2
// global variable
// main function
void main(void)
//Motor stop
CW = 0;
CCW = 0;
CCPR1L=0;
CW=0;
CCW=0;
CCPR1L=temp;
CW=!CW;
CCW=!CW;
CCPR1L=temp;
delay(5000);
if(temp>0)temp-=1;
CCPR1L=temp;
delay(5000);
