+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 4
    Points: 1,091, Level: 7
    Join Date
    Oct 2009
    Sri Lanka
    Posts
    73
    Points
    1,091
    Level
    7
    Sony Ericsson DCU11 to DRC11
    I wanted to interface sony ericsson k700 phone to PIC using DRC11
    (RS232) cable. But I was unable to find DRC11 cable in the market.
    I have DCU11(USB) cable. I have schematic of DRC11 cable But not DCU11 cable. If you have some detail about DCU11 cable, please tell me and guide me to do this clearly.
    Thanks............
  2. #2
    Newbie level 1
    Points: 562, Level: 5
    Join Date
    Nov 2009
    mx
    Posts
    Points
    562
    Level
    according to the schemmatics that i found in thiss page
    http://www.clubsonyericsson.com/foro...?topic=23626.0
    the #6 pin is RxD
    the #7 pin is TxD
    #9 + 3.3 v
    #10 GND
    for the rs232 connection i hope it works for you
    1 members found this post helpful.
    •   Alt11th November 2009, 02:46
      advertising
  3. #3
    Member level 4
    Join Date
    Oct 2009
    Sri Lanka
    Posts
    73
    Points
    1,091
    Level
    7
    Re: Sony Ericsson DCU11 to DRC11
    Thank you very much
    What is the function of DCU11 cable . Is is USB to serial conversion
  4. #4
    Member level 1
    Points: 1,340, Level: 8
    Join Date
    Jul 2009
    Uruguay
    Posts
    34
    Points
    1,340
    Level
    8
    Hi Amila, in my case I bought a DCU-11 cable I removed the usb to serial converter and only I used the mobile connector.
    About phone connecor I've used pin 4 (Rx), pin 5 (Tx), pin 10(GND), and pin 11 (power)
    •   Alt12th November 2009, 16:05
      advertising
  5. #5
    Newbie level 2
    Points: 495, Level: 4
    Join Date
    Mar 2010
    singapore
    Posts
    Points
    495
    Level
    Does it work?
  6. #6
    Member level 4
    Join Date
    Oct 2009
    Sri Lanka
    Posts
    73
    Points
    1,091
    Level
    7
    THIS IS WORKING FINE.DRC11 SCHEMATIC
    http://www.allpinouts.org/index.php/...cable_cell.png
    regards
    Amila
  7. #7
    Newbie level 2
    Join Date
    Mar 2010
    singapore
    Posts
    Points
    495
    Level
    Amila,
    I mean have u tried what fiolin says by cutting off the USB head and take the TX and RX pns of the phone and connect to the PIC?Does it work cause I am stuck as i cant find a rs-232 cable for the phone.Thanks.
    •   Alt14th March 2010, 06:17
      advertising
  8. #8
    Member level 4
    Join Date
    Oct 2009
    Sri Lanka
    Posts
    73
    Points
    1,091
    Level
    7
    We should take RX, TX nad GND pin of the phone. then it works. If you want you can use just a connector of the USB data cable to connect above three pins.
    Just cutting USB head and connecting RX,TX will not work.
    regrds,
    Amila
  9. #9
    Newbie level 6
    Points: 506, Level: 4
    Join Date
    Jun 2010
    Posts
    14
    Points
    506
    Level
    hi guys... well i'm doing the similar project as amilla and also use k700 in my project... using the max232 circuit and the dcu11 cable, i've tried to communicate to my phone using hyperterminal... but nothing show up... can anybody help me here? thanx in advanced... ^_^
