What is the formula to calculate power of transistor?
nareshgtr
Member level 3
Bangalore
Transistor power rating
hi guys,
I found 1W, 2W transistors with same current rating. How it is possible. What is formula to calculate power of transistor.
Thanks advance
V. Naresh Kumar.
if they have the same current rating, they proberly have different voltage span rating, so the effekt will be different !!!
Re: Transistor power rating
sorroy Mr.BWS, I didn't get.....diffferent voltage rating span means.... do you mean different Vce(sat)
different voltage span means that one transistor can handle greater voltage then the other one
yes thats what i mean :D
Or maybe a different casing .... bigger casings will help dissipate or conduct more heat to the outside I guess.
