How can get High speed ECL serial data with a xilinx fpga
koraei
Newbie level 3
hi
I want to get a 52 Mbps serial data by fpga in ECL format.
but i didnt see any document tath confirms that xilinx FPGAs like spartan III 400 or Virtex II Pro can get ECL as input .
Thanks for your help.
Can you clarify which type of ECL you have? For example 10K and 100K ECL have negative voltages, and won't interface directly to the FPGA. However, if you have positive ECL, then you may be able to use the FPGA's LVPECL I/O standard.
Re:
thanks
but I need to get negative ECL with voltage levels ( -0.8 v and -2.0 v)
thanks again for your guidence.
You probably need an ECL-to-LVCMOS or ECL-to-LVTTL translator, depending on whatever voltage range your FPGA requires.
For example, here's a possibility from ON Semi:
https://www.onsemi.com/PowerSolutions/product.do?id=MC100EPT25
Also try Texas Instruments and National Semiconductor (and probably several other companies), or simply Google for keywords such as: ECL translator LVCMOS LVTTL 3.3V 2.5V.
Re: How can get High speed ECL serial data with a xilinx fp
thanks alot echo47
You help me me very much.
I hope that I,ll able to make up this nice manner of you latter.
thanks again.
koraei.
