Wrong simulation for VP0808 mosfet?
clros
In this simulation (I am using multisim 14.0), the output voltage value (measured from XMM1) multimeter is:
~0V when S1 is on VDD
~0V when S1 is on GND
3.3V when S1 is on VSS
But, if I make this circuit on Breadboard whit a real VP0808, it do not faithful to simulation (I have 3.3V when S1 is on GND).
Is it a simulator error?
Do you understand the meaning of Vgs(th) specification in datasheet, particularly the wide threshold voltage range?
If I understand well, for P-MOSFET, the Vgs should be less than Vth:
Vgs < Vth
When I connect my gate to Vdd I have Vgs = 0V
When I connect the gate to GND, Vgs = -3.3V
When I connect the gate to Vss, Vgs = -6.6V
It is correct?
In this case, my Spice model have than VTO = -3.55V. If I connect gate to GND, the Vgs < Vth is false and I have 0V to drain pin.
Can anyone help me, please?
I thought you already answered the question yourself. You have explained the simulation result, the real MOSFET has apparently much lower threshold voltage, well possible according to the datasheet.
Yes, OK.
I would like to get a behavior like the one described by the simulator, in particular that the mosfet does NOT lead when Vgs is equal to GND.
So I should choose a MOSFET with a fairly high Vth. Could you suggest such a component?
Max. Vgs,th of 4.5V of VP0808 is relative high, you probably won't find any devices with Vgs,th,min > 3.3V.
