Calibre LVS Error with missing connection.
Trafford
I got this error in my LVS report. My layout and my schematic both connect good, however the report shows missing connection in my Source Netlist. I wondering where is the Source Netlist from? How to solve this problem?
Thanks!
Assuming you used Calibre Interactive to set up the LVS run, it is in the Inputs pane, Netlist tab. (You are expected to specify it.) You should see "Export from schematic viewer" checked if it is coming from the schematic.
For more details, see the manual -- it will be in $CALIBRE_HOME/docs/pdfdocs/calbr_inter_user.pdf or something like that. (I might have missed a few directories between "docs" and "pdfdocs"; it has been a while.)
