T
treez
For an FMMT491A BJT with 2.7mA flowing into its base and set up in common emitter mode….is there any set of circumstances (temperature, i(ce) etc etc) which might ever result in its Vce(ON) voltage ever being greater than 0.5v?
Its collector current is always less than 40mA
From the datasheet I see not, but is there any gremlin situation?
FMMT491A datasheet
https://www.diodes.com/assets/Datasheets/FMMT491.pdf
FMMT491A datasheet
