- Joined
- Jan 22, 2008
- Messages
- 52,520
- Helped
- 14,760
- Reputation
- 29,802
- Reaction score
- 14,129
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 298,523
Re: determining the frequency of nco implemented in fpga
You can try to run signal tap from a generated fast PLL clock, e.g. 200 to 300 MHz. Unfortunately it may upset design timing closure unless you declare the respective domain crossings as false path.
Supplementing to what ads-ee already explained. You're no seeing the real frequency of the 50 MHz clock because it's undersampled, counting edges gives an apparent frequency of about 15 MHz (65 - 50 MHz).but why system clock dont have 50 % duty cycle
