mcaduser
Newbie level 5
At the end of my APR, I am getting IO pad short between two pins in one particular metal layer. This happens even after running ECO route and even though this particular location is not metal congested. I'm not sure why this happens. I can fix this manually easily, however I'm trying to come up with an automated way of doing this and would like to understand if there is a tool command or something else I might doing that is causing this short.
I'm attaching a screen capture showing the short of two IO pins both trying in the same metal layer (8) to route pins that are very near each other.
Thank you for your help.
