Delay configuration completion by DLL
Tetra
Junior Member level 1
I read in xilinx data sheets that I can delay the configuration of the FPGA until an internal DLL reach lock state how can I do that.
DLL macros have an external pin labeled "LOCKED". This pin shall remain in a low state until the dll generated clocks are stable (frequency and duty cycle).
I know that, so should I tie this pin to external output pin and control the ~INT pin to delay the DONE signal ?, or there is an internal methode ?
Sorry, I believe I didn´t understand you. If you want DONE pin to be high after DLL locks, you have a checkbox for that in the options for the program file generation (I belive it is in the Startup section).
