watertreader
Full Member level 3
Have a little confusion about decibel. I know that to obtain decibel of a power type of quantity you will use 10 log P. while for voltage you will use 20 log V.
However, if the physical quantity I am measuring is in power or intensity. But the output measurement I am taking is in voltage or current... which is the correct form which i should express decibel as?
THanks for your help!
