siboy
Member level 3
The layout from SE, after I do lvs with Calibre, threr are over one hundred errors in lvs report, I don't know what's the problem? Can someone help me? Thanks!
here's some errors in lvs report:
CELL COMPARISON RESULTS
Error: Different numbers of ports (see below).
Error: Different numbers of nets (see below).
Error: Different numbers of instances (see below).
Error: Connectivity errors.
LAYOUT CELL NAME: DFCLRBEHD
SOURCE CELL NAME: DFCLRBEHD
NUMBERS OF OBJECTS
Layout Source Component Type
Ports: 15 8 *
Nets: 18 24 *
Instances: 10 18 * MN (4 pins)
4 18 * MP (4 pins)
Total Inst: 14 36
INCORRECT NETS
DISC# LAYOUT NAME SOURCE NAME
1 Net 3 LD
** missing connection ** MMGI_141:g
** missing connection ** MMGI_220:g
M0(0.440,0.960):g ** unmatched connection **
** unmatched connection ** MMGI_221:g
2 Net 11 MPW
M13(11.040,1.840):g ** unmatched connection **
M10(5.820,2.240):s ** unmatched connection **
M9(11.040,0.360):g ** unmatched connection **
M6(6.150,0.400):s ** unmatched connection **
** unmatched connection ** MMGI_24:g
** unmatched connection ** MMGI_16:s
** unmatched connection ** MMGI6:s
** unmatched connection ** MMGI_142:g
** unmatched connection ** MMGI8:g
** unmatched connection ** MMGI_21:s
** unmatched connection ** MMGI3:s
5 Net 1 ** no similar net **
6 Net 2 ** no similar net **
7 Net 5 ** no similar net **
NUMBERS OF OBJECTS
Ports: 15 8 *
Nets: 18 24 *
4 18 * MP (4 pins)
Total Inst: 14 36
INCORRECT NETS
1 Net 3 LD
2 Net 11 MPW
