Simulate the output noise of a single transistor
micasa
Newbie level 6
output noise site:edaboard.com
Hi everyone,
I want to simulate the drain current noise of a single transistor at the output. I am
not sure that I set up the test bench correctly. Please give me your comments.
Thanks in advance
Hi
If You need noise current You should set noise current tab, I think.
Then you should disable port noise if you need transistor noise only.
Regards
