...yes, but...
From post #4:It will work...
it will still work...
Why do you ask again and again.
The previous posts still answered:
From post#2:
From post #4:
Klaus
as long as the 3 feet transmitter antenna can broadcast 30 megahertz radio waves over several hundred miles, i will be happy.
Adding capacitive or inductive 'loading' to change the apparent length of the antenna doesn't necessarily make it work better but it does make the transmitter happier. Looking at it in the extreme, if you just used a small coil instead of an antenna it wouldn't work very well at all. On the other hand a walkie-talkie on 30MHz would be unwieldy if it had a 10 metre long antenna sticking out of it. Needless to say that you would have difficulty walking under bridges or through doorways with it!
Loading isn't the perfect solution to making usable antennas but it lets a good compromise be found between the electrical and physical requirements. The other factor in this is called 'impedance matching', without going in to boring math, a transmitter is designed to have a particular output impedance, typically 50 Ohms for radio applications and that means it will deliver most power to a load that also has an impedance of 50 Ohms. For any fixed frequency, if you could magically change the antenna length (think of elastic wire) its impedance would swing from low to high according to length. In fact it would repeat the pattern of lows and highs as the length got longer and longer. To get the maximum transmitter power for an antenna that for practical reasons can't be the best length, a loading inductor is added to make the impedances match each other. It isn't a substitute for the ideal antenna but it makes the best of what is convenient.
Brian.
Great - now we are really getting to the real problem. And good on you for getting into amateur radio - there are a lot of us around, there are very many aspects (WSPR, digital, moon bounce, fox hunting......) and there are always lots of people who are willing to help when you ask specific questions.i am thinking about getting into ham radio.
I know this has already been covered elsewhere.as long as the 3 feet transmitter antenna can broadcast 30 megahertz radio waves over several hundred miles, i will be happy.
