Results 1 to 5 of 5
    Full Member level 5
    Points: 2,214, Level: 10
    Jul 2015
    Faridabad India
    253
    2,214
    10
    Microcontroller pin not working after some time.
    Hello experts
    I made a pcb with pic18f25k20 microcontroller. I programmed it and powered it for few days. After 2 weeks microcontroller pin that connected with 7segment/3digit display dot pin stopped to working.
    In the circuit microcontroller pin connect to 7seg pin with a series resistance 470E. 3.3v power supply for whole circuit.
    3.3/470 = 7ma
    Microcontroller pin capable to carry 25ma according to datasheet. I wonder why this pin stopped to working.
    I will be thankful if you give me some advice about it.
    Points: 25,005, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,790
    25,005
    38
    Re: Microcontroller pin not working after some time.
    ESD? Over-temperature?
    Full Member level 5
    Jul 2015
    Faridabad India
    253
    2,214
    10
    Hamm
    May be not protect to every pin from electrostatic discharge. I never seen any additional circuit with 7seg display. It will be best practice if external protection against ESD, EOS etc.
    Second is temperature, that i didn't measure. May be it can be cause of fault. A 0.5va 230 to 12v transformer is present near by controller but not more close.
    Points: 30,261, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    9,055
    30,261
    42
    Blog Entries
    9
    The current driving the 7-segments display sounds comfortably dimensioned, so it is unlikely that there was a burning problem, except of course due to improper handling when energized; frankly, I believe that the problem lies in programming scope, review the code to check this possibility.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Points: 8,093, Level: 21
    Jan 2015
    1,136
    8,093
    21
    How did it stop working? What tests did you do to confirm it? (i.e. did you check with a scope, DVM etc.)
    When you powered the device off and (a little later) back on again, did it start working again or is it permanently 'dead'?
    Susan
