Results 1 to 8 of 8
    Newbie level 6
    Points: 388, Level: 4
    Feb 2018
    14
    388
    Functionl Generator 600 MHz
    My task is to create a Function generator upto 600 MHz frequency.
    Can anybody give me idea how to construct it or a block diagram or links?
    Thanks in advance.
    Points: 261,937, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,779
    261,937
    100
    Re: Functionl Generator 600 MHz
    Please some more snippets of specification. Waveform, rise-/falltime, pulse width, magnitude, just to mention a few parameters.
    Newbie level 6
    Feb 2018
    14
    388
    Nothing is given except frequency.
    Can you suggest me general block diagram for it?
    Points: 15,100, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,507
    15,100
    29
    Function generator, like a sine, wave, triangle wave generator?
    At 600 Mhz, you either have pure sine waves or a trapezoidal waveform.
    Because of the large amount of harmonics present in a square wave, it is simply not feasible to generate a square wave. Specially if you are pretending a 5 volt swing.
    Please Google LVDS, such that you the constraints you'll be facing..
    My batteries are recharged by "Helpful Post" ratings.
    Points: 11,906, Level: 26
    Aug 2015
    Melbourne
    1,948
    11,906
    26
    this seems like a uni assignment ...
    Points: 7,900, Level: 21
    Jan 2015
    1,108
    7,900
    21
    You also need to think about what the lower end of the frequency range is.
    There are a lot of circuits out there for "600MHz vco" (the google search I did) but many only have a limited range (say 300MHz to 600MHz)
    Susan
  7. #7
    Points: 34,110, Level: 45
    Oct 2001
    4,867
    34,110
    45
    The AWG presented in the link below, perhaps is the only device on the market that goes up to 600MHz. Usually the AWG generators sold by the big manufacturers goes only up to 120MHz.
    In the link is presented the block diagram of the device:
    https://www.zhinst.com/products/hdaw...AAEgIoVvD_BwE#
  8. #8
    Junior Member level 2
    Points: 226, Level: 2
    Apr 2019
    21
    226
    You may take a look how to utilize SDR as a signal generator - see the following as an example - https://www.rtl-sdr.com/tag/signal-generator/
