Lower frequency comb generator
Sonnyx1
Newbie
Newbie level 2
Hello,
I need to design a comb generator, where the output needs to be stable from 150kHz to 30MHz and the output signal needs to also be somewhat amplified. In the stable area there should be around 10 to 15 spikes, so I was thinking of a fundamental frequency round 2MHz. Some of the designs I have looked at have all higher frequency ranges. I have very limited knowledge in this field and it's my first time making a curciut like this, so any and all help or design suggestions will help me a lot.
Thank you in advance.
If you want 10-15 spikes per cycle then by your description an 'AND' gate is able to do the switching task. Feed plain DC pulses to the two inputs.
If one signal is low amplitude, then use a transistor as a class A amplifier. Send the soft signal through the bias. Send the stronger DC pulses through the collector.
If both signals need to be amplified, then send them as bias through two transistors in classic 'AND' gate formation.
