Results 1 to 3 of 3
    Full Member level 1
    Points: 1,109, Level: 7
    Jul 2016
    105
    1,109
    7
    A hole for Plastic pin of ethernet connector
    Here the ethernet connector(http://www.kosmodrom.com.ua/pdf/HR911105A.pdf) that I am going to implement in Altium.
    I need to know that for plastic connector (phi=3.25) if my configuration is right. (hole size=3.25 , X/Y for round shape=2.5)
    Points: 261,889, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    Re: A hole for Plastic pin of ethernet connector
    No. You'll use non-plated hole for mechanical alignment or locking pins, without annual ring etc.
    Full Member level 1
    Jul 2016
    105
    1,109
    7
    Thank you for your response. It means just by adjusting the hole size and disabling plated option ( even annual ring=0?) it works fine?
