Results 1 to 6 of 6
    Member level 3
    Points: 659, Level: 5
    Jan 2018
    64
    659
    Ground plane in audio amplifier?
    Hello, a question: can a ground plane, create problems in power audio amplifiers?
    Example: if touching the input with the tip of whatever, the amplifier oscillates, can it be the fault of the ground plane? (Which is on both layers, bottom and top) Or is it because the amplifier is unstable?
    Points: 24,487, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,702
    24,487
    38
    Re: Ground plane in audio amplifier?
    The amplifier is obviously unstable. But is it because of the plane? Perhaps the additional capacitance of the plane is the problem. You need to analyze the circuit a little more closely, considering the plane caoacitance.
    Member level 3
    Jan 2018
    64
    659
    Quote Originally Posted by barry View Post
    Thank you for the answer.
    Newbie level 3
    Points: 587, Level: 5
    Oct 2016
    TURKEY
    587
    What is your amplifier IC , grounding method is important
    ex: star grounding
    Points: 79,000, Level: 68
    Apr 2014
    16,044
    79,000
    68
    Many unexperienced people "fill" the spaces between traces and think this now is a GND layer. But it is not!
    From the electrical view, a GND layer needs to be a low impedance ... thus a GND layer should be solid, without any traces in this layer.
    Only if you really know what you do .. you may insert some traces at uncritical areas. .. or split the GND plane.
    Low Impedance:
    Don´t mix it with "low ohmic".
    * low ohmic is a "DC" value. It mainly is the copper resitance between two points. Thicker and wider traces will reduce resitance.
    * but "low impedance" is an AC value. (You know that an amplifier does not oscillate with DC frequency ). Unfortunately wider, or thicker traces, or copper filled areas do not necessarily reduce impedance that much.
    Points: 29,849, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,911
    29,849
    42
    Blog Entries
    9
    it is likely being not self oscillation as you think, but rather a bare injection of EMI ( e.g , from mains ) through your fingers.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
