Register Log in
[SOLVED] Ground plane in audio amplifier?
northumber82
Member level 3
Hello, a question: can a ground plane, create problems in power audio amplifiers?
Example: if touching the input with the tip of whatever, the amplifier oscillates, can it be the fault of the ground plane? (Which is on both layers, bottom and top) Or is it because the amplifier is unstable?
barry
Advanced Member level 5
California, USA
The amplifier is obviously unstable. But is it because of the plane? Perhaps the additional capacitance of the plane is the problem. You need to analyze the circuit a little more closely, considering the plane caoacitance.
northumber82
Member level 3
Thank you for the answer.
Riphagen
Newbie level 3
TURKEY
What is your amplifier IC , grounding method is important
ex: star grounding
KlausST
Super Moderator
Staff member
Many unexperienced people "fill" the spaces between traces and think this now is a GND layer. But it is not!
From the electrical view, a GND layer needs to be a low impedance ... thus a GND layer should be solid, without any traces in this layer.
Only if you really know what you do .. you may insert some traces at uncritical areas. .. or split the GND plane.
Low Impedance:
Don´t mix it with "low ohmic".
* low ohmic is a "DC" value. It mainly is the copper resitance between two points. Thicker and wider traces will reduce resitance.
* but "low impedance" is an AC value. (You know that an amplifier does not oscillate with DC frequency ;-) ). Unfortunately wider, or thicker traces, or copper filled areas do not necessarily reduce impedance that much.
Klaus
andre_teprom
Super Moderator
Staff member
Brazil
it is likely being not self oscillation as you think, but rather a bare injection of EMI ( e.g , from mains ) through your fingers.
Toggle Sidebar
