Polarization MOSFET SOI
lufer17
Member level 5
Hello everyone, I have a question about the N channel MOSFET SOI N, how is the device bulk polarized?
P- to intrinsic, depending on the desired VT. Either a
desirable starting material doping, or VT adjust implants.
Questions:
1. What do you mean under "polarized" - applied voltage, or doping type? (I think, you mean the former).
2. What do you mean under "bulk" - body of SOI MOSFET, or substrate region under BOX?
3. is this FDSOI or PDSOI? (i.e., fully depleted or partially depleted?).
Questions:
1- yes applied voltage
2-region of the substrate where is the VG2.
3-FDSOI
Objective: use as amplifier
Applied voltage varies with technology and application environment.
Ground (or negative rail) is common, but SOI technologies meant for
space and other radiation environments may apply a more negative
potential (which might then risk turning on the PMOS back channel,
there's a "BOX bias box").
In FDSOI technologies, adaptive back bias (voltage applied to substrate or well under BOX) is a popular and common technique to control leakage vs performance tradeoff.
Positive voltage will lower Vt for nMOSFET, and increase its ON current.
When device / block goes to off state, bias can be zero or negative.
See, for example, here:
http://semiengineering.com/the-return-of-body-biasing/
or here:
