Page 2 of 2 FirstFirst 1 2
Results 21 to 25 of 25
  1. #21
    Points: 14,152, Level: 28
    Apr 2014
    2,215
    14,152
    28
    Re: Is there possibility to force a filter topology in DA_LClowpassMatch in ADS?
    Quote Originally Posted by frdm90 View Post
    For example, if i will put the filter elements, and after that, i will make matching to 50ohm - it will be very bad?
    No, that is a good and valid design approach. It also allows to test your device with 50 Ohm test equipment, independent of the load + matching network.
  2. #22
    Points: 30,418, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,458
    30,418
    42
    Append to volker..
    Choose the Filter's Input Output Real Impedances carefully regarding to those impedances to be matched. Choose appropriate values so that matching circuit won't consist of weird elements..
  3. #23
    Member level 4
    Points: 5,651, Level: 17
    Feb 2002
    Switzerland
    68
    5,651
    17
    Here is a fictitious example for illustration: Load impedance: 1 Ω + 2.55 nH
    Matching frequency: 500 MHz
    Source impedance: 2 Ω / 6 Ω / 20 Ω (selectable within certain limits)
    Matching made with a low "pass structure" (n=4). As you can see, there is no well defined passband.
  4. #24
    Points: 260,228, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,442
    260,228
    100
    frdm90 didn't yet release a matching bandwidth specification. I presume, it's not possible to achieve a higher bandwidth with LC network for the example matching problem.
  5. #25
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,458
    30,418
    42
    You cannot match over this bandwidth with simple few matching circuit.Load Impedance is not constant and varies by frequency..
    Is your intention to match these termination impedances ( both source and load ) over the bandwidth..?
    Simple matching circuit wouldn't work.. Impedance Matching Transformer ( not exact but approximate) may be a solution but matching is not guaranteed at lower frequencies.
