Results 1 to 3 of 3
    Advanced Member level 2
    Points: 2,211, Level: 10
    Aug 2016
    578
    2,211
    10
    MOSFET instead of planar resistors
    Is it fine to employ to220/247/3P MOSFETs as resistors inplace of similarly packaged planar resistors for constant loads and for switched loads?
    The NMOS would be biased with a precision pot at its gate using a DMM from power supply to drain to make the current precise.
    Constant load.
    Switched load.
    Points: 260,190, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,437
    260,190
    100
    Re: MOSFET instead of planar resistors
    1. Don't expect stable current in this circuit due to temperature dependent Vgs/Id characteristic. Some kind of feedback suggested.
    2. Consider reduced power rating of MOSFET in linear mode caused by inhomogeneous current distribution. Check SOA in datasheet.
    Aug 2016
    578
    2,211
    10
    What feedback arrangements are there without high speed opamps?
