Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
  1. #21
    Junior Member level 2
    Points: 193, Level: 2
    Jan 2019
    20
    193
    Re: Sonnet Installation in CentOS 7
    I've searched in both directories (/home/JLHW and /root). in /home/JLHW, there are no .profile or .cshrc found, .cshrc is actually at /root, and .profile is not found here as well.
    I've tried modify .cshrc by adding:
    SONNET_DIR=/opt/sonnetsoftware/sonnet_16.52; export SONNET_DIR
    PATH=$PATH:$SONNET_DIR/bin; export PATH
    DISPLAY=:0; export DISPLAY
    but the error still shows.
    Should I manually create .profile at /home/JLHW and just copy the above codes?
  2. #22
    Points: 29,353, Level: 41
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,262
    29,353
    41
    Quote Originally Posted by JLHW View Post
    Where did you entered Design Environment Variables for Cadence ADE ?? You should insert Sonnet script into this file.
    I presume that you can launch Cadence ADE as a ordinary user right ?? The same procedure is valid, where they are , put this script in the same file whatever is..
  3. #23
    Jan 2019
    20
    193
    I've copied the script into both .bashrc files (in /root and $HOME) and it finally initialised.
    I've also copied the sonnet.cdsenv file into both my working directory and /opt/cadence/IC617/tools.lnx86/dfII/etc/tools/sonnet, renamed them to .cdsenv, then chmod 755 them.
    (For future readers who read this, in case the word "Sonnet" is still not visible in Layout L, just click Launch --> Sonnet)
    Your patience in helping and explaining things to me are highly appreciated, thank a lot!
