Even stranger, they want it to control an analog joystick. Attaching a joystick to an SMD IC sounds like a recipe for it being ripped off the board to me. :???:What? You want to amplify a POTENTIOMETER?
Are you saying you want to put more current through the device than it can handle? Why? Maybe if you told us a little more about what you’re actually trying to do.
impossible to answer without the requested informations.
--> Show a schematic and give values and give your requirements.
This code used to control the digital potentiometer
MCP41100 connected to arduino Board
CS >>> D10
SCLK >> D13
DI >>> D11
PA0 TO VCC
PBO TO GND
SHDN >> 9
PW0 TO led with resistor 100ohm .
#include <SPI.h>
byte addressPot0 = 0b00010001; //To define potentiometer use last two BITS 01= POT 0
byte addressPot1 = 0b00010010; //To define potentiometer use last two BITS 10= POT 1
byte addressPot0and1 = 0b00010011; //To define potentiometer use last two BITS 10= POT 0 and 1
byte CS= 10; //Chip control goes to pin 10
byte SHDN = 9; //Chip SHUTDOWN - PIN 9
byte RS = 8; //Chip RESET - PIN 8
void setup()
pinMode (CS, OUTPUT); //CS - When High, sets chip to read the data.
pinMode (SHDN, OUTPUT); //CS - When High, sets chip to read the data.
pinMode (RS, OUTPUT); //CS - When High, sets chip to read the data.
digitalWrite(SHDN, HIGH); //Power ON (HIGH)
digitalWrite(RS, HIGH); //Power NO RESET (LOW)
SPI.begin();
void loop()
PotHighAndLow_mt(addressPot0); //Change POT values on Pot0
PotHighAndLow_mt(addressPot1); //Change POT values on Pot1
PotHighAndLow_mt(addressPot0and1); //Change POT values on both
digitalPotWrite(245, addressPot1);
digitalWrite(SHDN, LOW); //Power OFF (LOW)
delay(5000); //delay for 5 seconds to test current consumption of potentiometer
digitalWrite(RS, LOW); //Power NO RESET (LOW)
delay(100); //delay 100 mls
digitalWrite(RS, HIGH); //Power RESET (HIGH)
delay(10000); //delay 10 sec
void PotHighAndLow_mt(byte address)
/* We have limit from 130 - 255 just for LED test, but for other projects it can be 0-255 */
for (int i = 130; i <= 255; i++)
digitalPotWrite(i,address);
delay(10);
// delay(500);
for (int i = 255; i >= 130; i--)
delay(10);
int digitalPotWrite(byte value, byte address)
digitalWrite(CS, LOW); //Set Chip Active
SPI.transfer(address);
SPI.transfer(value);
digitalWrite(CS, HIGH); //Set Chip Inactive
* We see no joystickUsed a MCP4261 to generate a signal to control a analog joystick, seems its max current is too small, anyway can amplification it's signal?
review your given informations:
* we see that there is nothing connected to the pot´s wiper
* we can´t know what current you talk about
.. and so on...
really a riddle...
Please review all your informations and give unambiguous informations.
It takes too much time for us to find out what you want to tell:
Some examples:
MCP41100 connected to arduino Board --> There is no MCP41100
CS >>> D10 --> There is no D10
SCLK >> D13 --> There is no D13
DI >>> D11 --> There is no DI and no D11
PA0 TO VCC --> There is no PA0
PBO TO GND --> There is no PBO
SHDN >> 9
PW0 TO led with resistor 100ohm . --> There is no PW0, no LED, and no information about the second connection of the LED
1. no joystick for now, just multi meter test the V at p6 and p9, and the output is the result. --> There is no p6, no p9. Measuring the voltage ... but initially you talk about current. and what do you mean by "result"?
Clarify all your informations of all your posts, because these are just a couple of doubtful informations.
