Results 1 to 4 of 4
    Points: 339, Level: 3
    Oct 2017
    7
    339
    [moved] I have a problem using waveguide port for my horn antenna in CST.
    I have multiple horn antennas that are located on a curve from phi=0 to phi=180 for rho=6cm. The problem is I have to use time domain solver in order to find the received signal versus time. Unfortunately in time domain due to hexahedral meshing, the solver gives me this error: Waveguide ports must be aligned with Cartesian coordinate planes for the transient solver. When using frequency domain solver with tetrahedral meshing this problem is solved, but the meshing is too high that for the first iterative solver it took one week. What should I do?
    Member level 4
    Points: 859, Level: 6
    Feb 2017
    74
    859
    Re: [moved] I have a problem using waveguide port for my horn antenna in CST.
    If they are the same antennas and if you think they wont interact with each other you can take field source of the horn and then use it for simulations.
    Oct 2017
    7
    339
    Actually I do need their interaction, because I need the signals received by each antenna when one of them is set to be a transmitter.
    Member level 4
    Feb 2017
    74
    859
    another solution to your problem is to design a waveguide bend. If you bend all of their guides to upwards or downwards you can place waveguide ports because now they will always be on the same cartesian plane.
