kangyunmei
Banned
Hi
I need some assistance to design a 12volt circuit to switch lighting in the cabin of an ambulance. Basically when the main lights are on, both LED strips are illuminated, however when the 'dim' button pressed, it will need to switch the brightest strip off but keep dim strip on. The set up is a 3 wire system, common -VE return with 2 + 12 volt feeds one for bright one for dim.
I know I will need some kind of switching circuit that will switch power off from bright strip when the dim button is pressed and power is fed through the dim wire but not sure how to create this. Can anyone help with a diagram and parts list??
