juz_ad
Full Member level 2
Hello,
I'm using a classic 2x transistor Schmitt Trigger design powered by +/12V rails.
If there was any minor changes in the output voltage of the plus or minus rails - e.g. between different OEM power supplies, or if the rails were operating at e.g +11.75 and -11.50 rather than exactly +/-12V...
...under normal use - would this factor by itself have any effect on the mark/space ratio between the high and low period?
I'm guessing not - but I was curious enough about to want to ask!
Thanks,
/ J
Thanks,
/ J
