nitinwa33
I am currently working on simulating a EM reverberation chamber in HFSS. The structure is a metal box with LPDA antenna and metallic stirrer inside of it. The metallic stirrer rotates around its vertical axis in discrete steps (0 to 360 degrees in 15 degree steps). At each rotation position, a frequency sweep is performed and Electric field data at various points inside the chamber is collected to see if the chamber is statistically uniform.
Dimensions of the chamber: L=6096 mm, W=3962 mm, H=2438 mm, Dimensions of the stirrer (each blade): Ls=1000 mm, Ws=1000 mm
My Approach:
1. I have placed 6 perfect E sheets to form a cube (shown in yellow in the figure) with chamber dimensions and placed antenna and stirrer inside of it.
2. Since a radiation box is needed for an antenna in HFSS, a radiation box (radiation boundary) outside the metal box (shown in figure) is created. I am a bit iffy about this part.
I am running the simulation on a server (with 256 GB RAM) and it takes a little over 24 hours for 6 frequency points between 300 MHz to 400 MHz (at each tuner rotation angle). This is understandable as the volume is pretty large. The problem is I am not seeing uniform electric field inside the chamber.
At this point I am not sure if there is something wrong with the way that I set up the simulation. Also is there a way to reduce the computation time of such large volume EM probelms in HFSS. Please let me know. Any help would be appreciated.
Thanks,
Nitin
My Approach:
Thanks,
Nitin
