Reflection Coefficient for unmatched condition
pancho_hideboo
Advanced Member level 5
Real Homeless
If Γin0=0 then Γin1=0=Γin0 for network N.
This is easy to prove.
Even if Γin0=x!=0 then Γin1=x=Γin0 for same network N.
This also can be satisfied.
But this is difficult to prove.
How can I prove this ?
  • RF_Matching.pdf
That is true for the reflection factor magnitude, not for the complex value.
The derivation that I am aware of is power conservation for lossless networks: reflected + transmitted = incident
thus |S11|^2 + |S21|^2 = 1
and for a reciprocal network with S21=S12 we then find |S11| = |S22|
True for complex value.
Wrong.
Only the magnitudes are equal, the phases depend on the network properties.
This is sometimes a useful degree of freedom for adjusting the source impedance on one side.
you cannot prove this! i believe its wrong
You are all correct.
Thanks for correction.
|ΔΓ| is used as metrics of backscatter strength in RFID Tag.
|ΔΓ| = |Γmod_on - Γmod_off|
For two unmatched conditions, state1 and state2, I expect following relation.
in0@state1- Γin0@state2| = |Γin1@state1- Γin1@state2|
Can this relation be satisfied ?
i used to do scattering parameters using wave theory. you can prove above equations using wave theory.
What do you mean by "wave theory" ?
Pseudo Wave Theory ?
Power Wave Theory ?
Not so easy, since reference impedances are different for port1 and port2.
And former is real number, latter is complex number.
Even if we use unitary matrix nature of S-matrix, proof is not easy.
However I can prove for matched case using unitary matrix nature of S-matrix, since equations are fairly simple in this case.
it can be done
https://en.wikipedia.org/wiki/Scattering_parameters
look at the proof they did for s-parameters wikipedia. i have a great book to suggest as well but forgot the name!
I also have my derivation done but its not with me currently.
its power wave theory
May I ask the name of the book? I study from Pozar, Razavi's and Radmanesh's books about the uWave/RF/Emt, it would be nice to learn a new one.
Could you clarify exactly what you mean by the terms in |Γin0@state1- Γin0@state2| = |Γin1@state1- Γin1@state2|?
Is the difference between state1 and state2 defined by a change in the properties of the impedance transformer between the source and load? Or a change in the load impedance?
A change in the load impedance under unchanged reference impedance value.
ZL0=20-j*35
[Example-1]
state1 : ZL=PortZ(4)=ZL0 / 50
state2 : ZL=PortZ(4)=ZL0 / 2
[Example-1]
state1 : ZL=PortZ(4)=1 / ( 50*real(1/ZL0)+j*imag(1/ZL0) )
state2 : ZL=PortZ(4)=1 / ( 2*real(1/ZL0)+j*imag(1/ZL0) )
in0@state1| = |Γin1@state1|
in0@state2| = |Γin1@state2|
Then I think the proof looks like:
in0@state1|- |Γin0@state2| = |Γin1@state1|- |Γin1@state2|
Which is a pretty trivial result. But I don't think that this:
Can be true in general.
edit: actually I see that it seems to hold true for test cases, interesting. I'll see about a proof....
