Results 1 to 13 of 13
    Member level 3
    Points: 1,117, Level: 7
    abhishek.2138's Avatar
    Dec 2013
    60
    1,117
    7
    Crystal Oscillator issue
    I am facing problem in RTC crystal oscillator circuit in automotive instrument cluster. The RTC works fine when date & time is set. The crystal oscillations are proper within frequency limits. But, sometimes the oscillations stops & the date & time gets reset.
    Datasheet for crystal R38, RTC IC & circuit is attached. I have calculated the safety factor & circuit margin for crystal. These values are within limits. The Vdd supply is 5V. I2C resistors are 1K each.
    What can be the root cause for it?
    Points: 27,308, Level: 40
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,171
    27,308
    40
    Blog Entries
    Re: Crystal Oscillator issue
    Review the RTC battery connection to the holder, to check if it is firmly tied.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Points: 36,229, Level: 46
    Mar 2008
    USA
    5,824
    36,229
    46
    I'd look at 5V supply noise / dropouts, maybe the ground as
    well. Self synchronous noise can "beat back" crystal oscillation
    if you get the right, wrong phase (for example too much load
    for a derived clock could bump the crystal through-the-ground
    current loop).
    Automotive environment has some nasty things like load dump
    that can blow through slow voltage regulators' low HF PSRR.
    Might look at what happens if (say) you interpose a common
    mode choke w/ stiff output capacitor between the system
    and the oscillator.
    Full Member level 1
    Points: 2,121, Level: 10
    Jan 2009
    95
    2,121
    10
    Recheck your crystal circuit.
    The RTC already has a integrated load capacitance [CL(itg), 15-35pF], wit ext. C16/17 you are adding 7.5pF on top.
    This will not only trim the crystal to get a clock deviation, but will also overstress the crystal. Osc.margin should also be considered for osc.startup.
    As a first task, remove C16&C17, and recheck operation.
    Member level 3
    Dec 2013
    60
    1,117
    7
    Quote Originally Posted by rho-bot View Post
    The load capacitance as per crystal datasheet is 10 pF typical & as per crystal datasheet (for R38 crystal) the load capacitance is 12.5 pF. Is it because of the difference in load capacitances the oscillations stops?
    On the CLKOUT pin, it is open drain. I have connected pull up resistor of 2K & observed waveforms on the output. On some instances I do not get waveform, but when I touch the crystal leads the oscillator starts that is the crystal is triggered. Whys is it so? Is it because of load capacitance values 12.5 pF not within tolerance (15/2 + 5 pF stray capacitance = 12.5 pF). CL tolerance is not given in crystal & IC datasheets. Even the load capacitors are removed, the crystal works fine?
    I don't understand the CL(itg) = (Cosci * Cosco) / (Cosci + Cosco); this is given on page 32 of RTC IC datasheet. In the RTC circuit Cosci = Cosco = 15 pF & it is mentioned in datasheet that CL(itg) = 25 pF (typical). For 25 pF CL (itg), Cosci should be equal to Cosco = 50 pF. This is bit confusing..
    What can be the root cause for this?
    The RTC battery connections are OK & Vbatt is also OK.
    Full Member level 1
    Jan 2009
    95
    2,121
    10
    Yeah, the datasheet & especially the footnote for CL(itg) is confusing & misleading, it should be rewritten
    Maybe best to check these NXP Application Notes:
    https://www.nxp.com/docs/en/user-guide/UM10301.pdf
    https://www.nxp.com/docs/en/applicat...te/AN10652.pdf
    Cosco has 25pf built inside the RTC, so no need for C17. Remove it.
    Keep C16 for Cosci. With 25pF, you should typ. reach 12,5pF load.
    Considering StrayC, PinC, BoardC and CapTolerances, you may need to do finetuning on C16, to get the needed clock accuracy.
    With this, your circuit should run.
    If osc. still doesn't start, or drops, it may be an issue with Oscillator margin mismatch. For this case, come back here again.
  7. #7
    Member level 3
    Dec 2013
    60
    1,117
    7
    The oscillator margin is within the limits. No problem for margin.
  8. #8
    Points: 61,824, Level: 60
    Apr 2014
    12,606
    61,824
    60
    Mind: datasheets show the circuit how it should be.
    Most datasheets are correct, thus - if the circuit doesn´t work - there may be a problem with your circuit.
    Please post photos of your circuit, where we can see all the wiring.
  9. #9
    Member level 3
    Dec 2013
    60
    1,117
    7
    Also, the oscillator starts when the crystal leads are touched by oscilloscope probe or by bare hand.
    This is big surprising why it happens? The load capacitance value is as per the crystal datasheet (12.5 pF)
  10. #10
    Full Member level 1
    Jan 2009
    95
    2,121
    10
    Please post your actual osc. circuit & pcb layout.
    Otherwise further help not possible, as I am not aware, which of my& other suggestions you followed.
  11. #11
    Member level 3
    Dec 2013
    60
    1,117
    7
    Please find the circuit.
  12. #12
    Apr 2014
    12,606
    61,824
    60
    S1J is a 600V 1A rectifier diode with standard voltage drop.
    I recommend to use BAT54C or similar. (there are cheaper ones)
    * smaller
    * cheaper
    * less voltage drop
    * less part count
    * less reverse current
    * faster (less trr means you get a smaller negative voltage spike when 5V is switched OFF; only valid for fast falling 5V)
  13. #13
    Full Member level 1
    Jan 2009
    95
    2,121
    10
    Quote Originally Posted by abhishek.2138 View Post
    OK, so you still did not consider to implement my hints for improvement... Feels bad, man
    Fix it first, and report back.
    Besides, what's the battery voltage B1?
    And give layout extract.
