Mahmoud_Dagher
Junior Member level 2
I'm using SoC Encounter for my implementation. Everything is fine except [verifyConnectivity report], I have 5 antenna problems : like
Net DATA_I[7]: antenna at (41.067500,182.975) on layer M3
NET KEY_I[4]: antenna at (47.0575,11.4425) on layer M3
NET KEY_I[4]: antenna at (44.41,182.815) on layer M3
NET KEY_I[5]: antenna at (46.11,112925) on layer M3
NET KEY_I[5]: antenna at (43.2625,182.98) on layer M3
I tried manually to adjust the wires but with no benefit, I also tried the repairing process antenna violations commands with NanoRoute but also with no benefit.
How can I fix these 5 antenna problems in those 3 nets to have a correct implementation before going to Physical Verification and Post layout Simulation?
-I attached screenshots of the nets in their antenna locations (As you see the location like reported is at when M3 is reaching the via with M2)
