jesuschrist
Member level 4
Hi. For my LNA design I was using tps7a4701 as a regulator to supply DC voltage to circuit. I designed the pcb according to datasheet and used any-out option and it should give 4V all times. Now i get a variable output at the output of LDO. when i give Vin=3V, ı get Vout=3V and this goes all the way to 5.42 volts Vout caps at 5.42 V even if i increase Vin.You can see the soldering below.What could be the cause of this ?
