Results 1 to 11 of 11
    Member level 5
    Points: 1,473, Level: 8
    Oct 2012
    92
    1,473
    8
    Interfacing a VGA port with a PLD
    I was planning to interface a VGA port with a Xilinx CPLD. I went across several schematics available at digilent site. In one schematic here, one I/O pin each (of FPGA) is assigned to Red, Green and Blue channels. In another schematic here 3 I/O pins are assigned to Red and Green channels and 2 I/O pins to Ble channel. Next, in yet another schematic here 4 I/O pins are assigned to Red, Green and Blue channels.
    **What could be the reason pls. ? Are multiple pins for 256 colour display? If not (I am tempted to guess otherwise as all the 3/4 pins are tied to single pin of the DB15 female connector), can I simply use one pin per channel and get the same output on VGA display instead of 2/3/4 pins per channel?
    ** Also, how were these resistance values calculated ? Is there any standard which governs the resistance value of the interfacing of the VGA port ?
    Thanking You,
    Arvind Gupta
    Points: 61,937, Level: 60
    Apr 2014
    12,624
    61,937
    60
    Re: Interfacing a VGA port with a PLD
    One pin per color: Color ON/OFF
    2 pins per color: 4 steps resolution: : 0%, 33%, 66%, 100% of colour (Did you recognize the different resistor values: 2k, 1k, 510R)
    3 pins per color: 8 steps resolution: : 0%, 14% ... 100%
    •   AltAdvertisment
    Points: 11,941, Level: 26
    Apr 2010
    1,830
    11,941
    26
    VGA interface have one pin assigned for each colour in analog form.
    •   AltAdvertisment
    Member level 5
    Oct 2012
    92
    1,473
    8
    OK. How were the values of the on board resistors decided here? Considering the basic configuration in which only one FPGA pin per colour channel is assigned (pdf link to schematic here), the voltage at FPGA pin can be up to 3.3 v. As per the user guide of the kit here (page 53), there is a 75 ohm termination built in the cable. If the value of the on-board resistor is R, then the equation comes out to be:
    R + 75 = (3.3-0.7) / I
    So what value of I should I take? Also if this sounds correct (which is my main motive behind this post), is there any recommended value of I (and consequently R)? Are there any VGA standards on the current to be sourced/ taken out from the VGA port?
    Similarly, how were the on board resistor values for HYSNC and VSYNC decided? Again, if it is R’, the maximum voltage at FPGA I/O pin is taken to be 3.3 v and with a 75 ohm termination built in the cable, the equation comes out to be:
    R’ + 75 = (3.3 - 0.7) / I’
    What would be the value of I’ which should be taken in this case? And again, if there are any VGA standards in this case recommending the current for these two pins pls?
    Back calculation with the given values reveal I =7.5 mA and I’= 16.5 mA (which are far apart from each other).
    In a nutshell, I wanted to understand how these values are decided and then if required, modify them in my case.
    Thanks and Regards,
    Arvind Gupta
    Apr 2010
    1,830
    11,941
    26
    No known current spec for such inputs(as far i know.)
    Since it is the monitor input that loads , that must be hi impedance with negligible current.
    for a 3.3v system RGB resistor can be calculated as around 278 ohms.
    no need for current spec.
    •   AltAdvertisment
    Apr 2014
    12,624
    61,937
    60
    nonsense.
    None of you both is able to have a look to Wikipedia? Or use an internet search engine?
    https://en.wikipedia.org/wiki/Video_Graphics_Array
    --> It specifies 75Ohms termination on both ends
    and 0.7Vpp signal level.
    So the spcification is here, but wether you keep on it is your decision.
    For a high picture quality you need to ensure 75R source impedance, but for a simple solution I´d forget about this, just rely o n the 75 Ohms in the monitor.
    if you have three 3.3V outputs and use 3 resitors then:
    all switched to 3.3V should generate 0.7V at the monitor (75 R)---then you need about 275 ohms source impedance.
    use 2k, 1k and 470R
  7. #7
    Member level 5
    Oct 2012
    92
    1,473
    8
    Thanks for the tips. Yes, I was able to calculate the resistor when single FPGA pin is assigned to each color channel (my calculated value came out to be 279 ohms; the value of resistance in the digilent schematic was 270 ohms.). I still have a few doubts though:
    1. In the Wikipedia page, the voltage mentioned for each colour channel is 0.7 v peak to peak. Should it not be 0.7 v peak.
    2. Why did they connect 82.5 ohms in HSYNC and VHYSNC ports. I suppose 75 ohm resistors should be available easily.
    Regards,
    Arvind Gupta
  8. #8
    Apr 2014
    12,624
    61,937
    60
    1) Yes, from your point of view, because you see positive voltages only. But I assume within the monitor the signal is AC coupled --> then the definition via Vpp is more adequate. (and fits in either case)
    2) The color signals have to be seen as analog signals. But HSYNC and VSYNC are digital signals with TTL levels. About <0.7V for LOW, >2.0V for HIGH. The sync signals are NOT terminated with 75 Ohms inside the monitor. But a series resistor (82 Ohms) at the driver reduces ringing.
  9. #9
    Member level 5
    Oct 2012
    92
    1,473
    8
    Hi there,
    I was trying to calculate the resistor values for inputs to the RGB channels with 3 bit resolution connected to the VGA port given in the digilent schematic here. I was not getting the values as per the schematic.
    For eg. the red channel has a 3 bit resolution. When Red0 will be high and other 2 inputs (Red1 and Red2) will be low, the input string for red channel will be ‘001’. In this case, the voltage at other end of the resistor should be 0.1v (assuming that 0.7v drop which is to be available at output pin of VGA is linearly divided in 8 divisions between 0.0v to 0.7 v) . So the resistance comes out to be:
    (3.3 - 0.1)/R17 = 0.1/75 (for 75 ohm termination)
    R17 = 2.4Kohms (as per the schematic it is 2.0Kohms)
    Similarly calculating for R18 (‘010’ input string and 0.2v drop at other end of the resistor), the value comes out to be 1.163Kohms. The schematic value is 1Kohms. And the calculated value for R20 is 543 ohms and whereas in the schematic it is 510 ohms.
    Can anyone point out the reason for this difference pls? Also, why has blue channel been given only 2 bit resolution against 3 bit resolution for red and green channels?
    Thanks and Regards,
    Arvind Gupta.
    •   AltAdvertisment
  10. #10
    Apr 2014
    12,624
    61,937
    60
    --> https://en.wikipedia.org/wiki/8-bit_color
  11. #11
    Member level 5
    Oct 2012
    92
    1,473
    8
    OK. And what could be the reason for difference in the calculated and schematic resistor values pls?
    Arvind Gupta.
