Results 1 to 9 of 9
    Member level 3
    Points: 1,315, Level: 8
    Dec 2012
    63
    1,315
    8
    synchronize data with general GPIO clk
    Hi friends
    I have a devboard (with cyclone V) which gets 10bit data + clk(83Mhz),
    The problem is that the clk is connected to a standard GPIO pin (not global), and no i don't have an option to reroute it.
    How can i synchronize this data to second clk2 domain with the same freq.
    I know there is a technique that i can synchronize this data with double/triple DFF, but how to connect the clk
    Gil
    Points: 60,582, Level: 60
    Apr 2014
    12,364
    60,582
    60
    Re: synchronize data with general GPIO clk
    What is your highest global clock frequency?
    Why can't you reroute it? Internally ... from one pin to another pin close to a clock pin, then connect it externally?
    •   Alt13th August 2017, 13:57
      advertising
    Points: 244,887, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,532
    244,887
    100
    Hardly. You need to sample the asynchronous clock and data with a considerably higher clk2 frequency. What's the relation of external clock and data?
    •   Alt13th August 2017, 14:16
      advertising
    Member level 3
    Dec 2012
    63
    1,315
    8
    83Mhz
    They are aligned with 0 degrees(but i can change it up to 180 degrees), due to nyquist law, is double freq will be enough?
    The problem is that the board designer made it by mistake and the board is already after assembly (no option to manually wiring)
    •   Alt13th August 2017, 14:48
      advertising
    Apr 2014
    12,364
    60,582
    60
    Due to nyquist you need higher than double.
    But if the global 83MHz clock is aligned to the 83MHz on the GPIO, where is the problem?
    Member level 3
    Dec 2012
    63
    1,315
    8
    The input Data & Clk1 are aligned, clk2 is not matched to clk1.
    Ok, so no way to get around it.
  7. #7
    Apr 2014
    12,364
    60,582
    60
    May I ask why both clocks are 83MHz?
    If you need more assistence, then provide all related schematics and PCB layout.
    •   Alt14th August 2017, 13:26
      advertising
  8. #8
    Points: 7,451, Level: 20
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germay
    1,094
    7,451
    20
    Blog Entries
    Assuming that your input clk and the 10bit are sync....
    I don't know about cycloneV but for Xilinx 7 series and above FPGAs there is an XDC command to be used when a normal GPIO pin carries a clock signal. Isn't there something similar with Altera/Intel?
    If there is, then use that command in your SDC file. There might be timing problems, but can be resolved by proper analysis (using proper input/output delays or inst. a delay element in the data path).
    As you do in the case of other signals. Using an async clk FIFO is perhaps the easiest way out.
    You should use this technique only for single bit signals. But your signal is a 10bit data, so use a FIFO to sync.
    .....yes, I do this for fun!
  9. #9
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,532
    244,887
    100
    A GPIO pin driving several register clocks will be automatically routed through a Cyclone V global clock network. But it can't be used as PLL reference clock.
    The feature to route a GPIO to a clock network is also the prerequisite for using a DC (domain crossing) FIFO for the design problem.
    If the data lines are known stable during a certain part of the clock cycle, the data can be consistently read in with a DFF synchronizer for the clock (and delaying DFFs for the data lines as far as required).
