Winston_rds
Newbie level 2
hi everyone,
I am working on RGB LED cube project. i finished building the cube. but later i found out that the LEDs are common cathode. but I was supposed to use COmmon Anode.
I am using NPIC16C595D shift register which has open drain outputs which can drive the PIN only Low. shift register board is already designed manufactured and soldered.
Now is there any way that I can still use the board with already built LED cube.
how to drive HIGH output from the shift register ?
I know I can use pull up resistor to drive HIGH. and what is the suitable value for the full up resistor ?
