not getting right result of ALU program in VHDL
abhiinics
Newbie level 3
Hello I have written the alu programm for adder, multi, divisor, subtractor.
I am getting output also but the output is not right.
Can anyone help me out by checking the ?
LIBRARY ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
-- Entity for ALU component
-- Use this Entity for your C&A project
ENTITY ALU_E IS
  PORT(
    reset_n     : in std_logic;
    clk         : in std_logic;
    OperandA    : in std_logic_vector(3 downto 0);
    OperandB    : in std_logic_vector(3 downto 0);
    Operation   : in std_logic_vector(2 downto 0);
    Start       : in std_logic;
    Result_Low	: out std_logic_vector(3 downto 0);
    Result_High	: out std_logic_vector(3 downto 0);
    Ready	: out std_logic;
    Errorsig	: out std_Logic);
END ALU_E;
architecture Behavioral_ALU of ALU_E is
signal product : std_logic_vector(7 downto 0);
signal sum, Q, R : std_logic_vector(3 downto 0);
signal diff : std_logic_vector (3 downto 0);
signal cout, b_out, err, Hold_Ready_Signal, Ready_Signal : std_logic;
component Addi is
  port(
    a,b :   in std_logic_vector(3 downto 0);
    cin :   in std_logic;
    cout:   out std_logic;
    sum :   out std_logic_vector(3 downto 0));
end component;
component adderSubtractor is
  port(
        a,b  : in std_logic_vector (3 downto 0);
	bin  : in std_logic;
	b_out: out std_logic;
	diff : out std_logic_vector (3 downto 0));
end component;
component Multi is
  port(
    output :   out std_logic_vector(7 downto 0));
end component;
begin
Ready <= Ready_Signal;
ADDITION: Addi
        port map (OperandA, OperandB, '0', cout, sum);
Subtract: adderSubtractor
        port map (OperandA, OperandB, '0', b_out, diff);
Multiplication: Multi
        port map (OperandA, OperandB, product);
process (reset_n, clk, Operation)
variable counter : std_logic_vector (3 downto 0);
variable rotate_A : std_logic_vector(7 downto 0);
variable a1,b1,r,q,temp3: std_logic_vector(3 downto 0);
variable w: std_logic;
begin
    if reset_n = '0' then
        Result_Low <= "0000";
        Result_High <= "0000";
        Errorsig <= '0';
        Ready_Signal <= '0';
        Hold_Ready_Signal <= '0';
        counter := "0000";
    elsif clk'event and clk = '1' then
     if(Start = '1') then  -- Start calculation
     counter := "0000";
        case Operation is
            when "001" =>
                rotate_A := "0000" & OperandA;
                --http://www.eng.auburn.edu/~strouce/class/elec4200/operat.pdf
                    while (counter < OperandB) loop
                        rotate_A := rotate_A(6 downto 0) & rotate_A(7);
                        counter := counter + "0001";
                    end loop;
                Result_Low <= rotate_A(3 downto 0);
                Result_High <= rotate_A(7 downto 4);
                Errorsig <= '0';
                Ready_Signal <= '1';  -- At every Ready_Signal: Calculation finished
            when "010" =>
                    while counter < OperandB loop
                        rotate_A := rotate_A(0) & rotate_A(7 downto 1);
                    end loop;
                Errorsig <= '0';
            when "011" =>
                        Result_Low <= OperandA xor OperandB;
                        Result_High <= X"0";
                        Errorsig <= '0';
            when "100" =>
                        Result_Low <= sum;
                        Result_High <= "000" & cout; -- carry (cout) + LSB of the Result_High
                        Errorsig <= '0';
            when "101" =>
                        Result_Low <= diff;
                        Errorsig <= b_out; -- Difference: Negative: Errorsig:b_out=1
            when "110" =>
                        Result_Low <= product(3 downto 0);
                        Result_High <= product(7 downto 4);
                        Errorsig <= '0';
            when "111" =>
						if(OperandA<OperandB) then                    -- DIIV operation
		        a1:= OperandA;
		        b1:="0000";
			Ready_Signal<='1';
		 elsif(OperandB="0000") then
		        Errorsig<='1';
            	 elsif(OperandA>=OperandB) then
                        a1:= OperandA;
                        temp3 :="0001"; Errorsig<='0';
                   while (a1>=OperandB) loop
                        r:= a1;
                        q:= b1;
			for I in 0 to 3 loop
                        a1(I):= r(I) xor OperandB(I) xor w;
                        w:= ((not r(I)) and OperandB(I)) or ( not(r(I)) and w)or (w and  OperandB(I));
                        end loop;
                        w:= '0';
                        b1(I):= w xor q(I) xor temp3(I);
                        w:= (q(I) and temp3(I)) or (w and (q(I) or temp3(I)));
                        end loop;
                        end loop;
		   Result_High<= b1;
	           Result_Low <= a1;
		   Ready_Signal<='1';
		end if;
            when others =>
						Result_Low <="0000" ;
						Result_High <="0000";
						Errorsig <= '1';
        end case;
    elsif Ready_Signal = '1' then    --- Hold Ready_Signal for 2 clock cycles
                if Hold_Ready_Signal = '1' then
                else
                    Hold_Ready_Signal <='1';
                end if;
    end if;
    end if;
end process;
end Behavioral_ALU;
thanks
what exactly is the problem? have you got a testbench?
Well don't expect your "program" to be synthesizable, it's not written to describe hardware. I suspect that is at the root of your problems. e.g. don't use variables (unless you actually understand how they can be used in synthesizable code), don't use while loops (they can't be synthesized)
