nexttym
Hi all
I have to measure S parameters for a differential line.But I have a constraint that it is not possible to measure coupling factors,s12(ie b/w adjacent ports) because of the close proximity of ports.Can you suggest a way to calculate the differential S parameters from single ended lines considering the constraint that I can place two probes at the same end..
Thanks in advance
Thanks in advance
