How to import a logo in Allegro PCB Design 16.3
gmarocco
Junior Member level 1
I would like to import a logo in Allegro PCB DEsign version 16.3. I' ve tried to import a dxf file and to map the content into the board geometry class> silkscreen top but I have found an empty board even if the import procedure is successful.
Could you give me some hints?
while importing dxf select incremential addition
It works for some dxf files but I don't understand why it doesn't work for all dxf files
How are you creating you dxf file?
Try opening your dxf file in some dxf viewer if it is opening in dxf viewer than it will be imported in allegro otherwise not.
It happens generally when you try to make dxf from a image file and than try to import it in allegro.
