+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Member level 5
    Points: 628, Level: 5
    Join Date
    Aug 2011
    Tirunelveli,Tamill Nadu, India
    Posts
    82
    Points
    628
    Level
    Which Pic microcontroller ?
    Hi, I have learnt 8051 and used 89S52. Now I would like to learn about PIC which controller should I use ?
    Pls specify a widely used PIC similar to 89S52 i.e commonly used for most projects...
    •   AltAdvertisment
  2. #2
    Advanced Member level 1
    Points: 3,016, Level: 12
    Jestin_cubetech's Avatar
    Join Date
    Jun 2012
    Posts
    499
    Points
    3,016
    Level
    12
    Blog Entries
    Re: Which Pic microcontroller ?
    PIC16F877A is a Commonly Used Micro controller.
    if you want learn USB and Need more memory space then Migrate to PIC18F4550
    One man's fault is other man's lesson...
    1 members found this post helpful.
  3. #3
    Full Member level 4
    Points: 1,731, Level: 9
    rparthiban69's Avatar
    Join Date
    Aug 2012
    Posts
    225
    Points
    1,731
    Level
    9
    PIC16F877A is mostly used microcontroller
    Thanks,
    Parthi
  4. #4
    Full Member level 1
    Points: 919, Level: 6
    manikandanshine's Avatar
    Join Date
    Aug 2012
    india
    Posts
    105
    Points
    919
    Level
    pic16f877a is most widely used microcontroller....it have a built in adc,3timers,spi,i2c,uart....its easy to use...try it.
    Thanks and Regards,
    MANIKANDANSHINE
  5. #5
    Member level 2
    Points: 794, Level: 6
    OunaLypse's Avatar
    Join Date
    May 2012
    Bushbuckridge, Mpumalanga, South Africa
    Posts
    50
    Points
    794
    Level
    The best for start level is PIC16F84.... even when you buy the programmer they give you a freebie PIC16F84
    Hasta La Vista, baby!
  6. #6
    Advanced Member level 5
    Points: 20,490, Level: 34
    Achievements:
    7 years registered
    Join Date
    May 2009
    Prime Meridian
    Posts
    3,056
    Points
    20,490
    Level
    34
    What language are you coding in ?
    The 16f877A is as good as any, or as said, the 18f4550 is you want to use USB, though complicated even using Microchips free C code.
    •   AltAdvertisment
  7. #7
    Member level 5
    Join Date
    Aug 2011
    Posts
    82
    Points
    628
    Level
    Thanks,..Then I will stick with 16f877
    I used keil for 8051 for pic ??
  8. #8
    Member level 2
    Points: 1,398, Level: 8
    matthai's Avatar
    Join Date
    Mar 2010
    KERALA
    Posts
    52
    Points
    1,398
    Level
    8
    it is very simple to program PIC using FLOWCODE. not require any C experience.
    http://www.matrixmultimedia.com/flowcode.php
  9. #9
    Points: 38,590, Level: 48
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,590
    Level
    48
    Blog Entries
    22
    Quote Originally Posted by Jeffrey Peter View Post
    mikroC is a very popular compiler. There's a free version available as well. http://www.mikroe.com/mikroc/pic/
    There are other compilers available, such as Hi-Tech C, mikroBASIC, PICBASIC, etc.
    Hope this helps.
    Tahmid.
  10. #10
    Full Member level 1
    Join Date
    Aug 2012
    india
    Posts
    105
    Points
    919
    Level
    hi-tech c compiler is nice to use as compared to other compiler....if u use hi-tech c compiler,you can able to write any type of coding for any controller family like atmel,microchip,freescale etc......
    Thanks and Regards,
    MANIKANDANSHINE
  11. #11
    Member level 5
    Join Date
    Aug 2011
    Posts
    82
    Points
    628
    Level
    Thank you ...
  12. #12
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,590
    Level
    48
    Blog Entries
    22
    Quote Originally Posted by manikandanshine View Post
    Are you sure about this?
    I know that mikroC can be used for many families:
    mikroC for dsPIC - mikroC PRO for dsPIC30/33 and PIC24 - C compiler for dsPIC30, dsPIC33, PIC24 - MikroElektronika
    mikroC for PIC - mikroElektronika - mikroC PRO for PIC - C compiler for Microchip PIC microcontroller development
    mikroC for ARM - MikroElektronika - mikroC PRO for ARM - C compiler for ARM Cortex M0, M3 and M4 device development
    mikroC for PIC32 - MikroElektronika - mikroC PRO for PIC32 - C compiler for Microchip PIC32 microcontroller
    mikroC for 8051 - mikroC PRO for 8051 2009 - C compiler for 8051 microcontroller - mikroElektronika
    mikroC for AVR - MikroElektronika - mikroC PRO for AVR - C compiler for AVR microcontroller device development
    If you're using mikroC, you may find this helpful:
    https://www.edaboard.com/group282-discussion1248.html
    Hope this helps.
    Tahmid.
    •   AltAdvertisment
  13. #13
    Full Member level 1
    Join Date
    Aug 2012
    india
    Posts
    105
    Points
    919
    Level
    because it didnt have any inbuild functions,so we are only responsible for all functions.......after throughly knowing about all details about that controller in the datasheet,we can write any coding....suppose microc and ccs compiler have own inbuild functions.by using these functions we can easily write any coding....so no need to study all details in the datasheet....thats why i said like that.....its my point of you mr.tahmid...
    Thanks and Regards,
    MANIKANDANSHINE
