Engine Control Unit (ECU) using dsPIC33F
hameeds01
Advanced Member level 2
Islamabad Pakistan
hello guys,
I made a Universal Engine Control Unit (ECU) using dsPIC33F equipped with DSP Engine, it can run any Gasoline 1,2,3,4,6,8 Cylinder Engine. it can also support VTEC/VVT, + lot more advance features
Have a look at it
https://www.youtube.com/watch?v=QJekC7DcIqk
Best Regards
Asad
Nice now we have ECU, then we should get rest of cylinders and other parts and we can drive. :-D
Very nice job, second version if goes on SMD will have only one PCB and will be smaller to. ;-)
Very nice.
What thise leds saying ?
Very nice.
Yup u r right man but the problem is that i am just a hobbyist i dont have any SMD PCB Fabrication facility.
LEDs shows the Status of Fuel Injectors, Ignition coils, IAC Position, VVT, Purge Valve, Fuel pump, Radiator Fan etc
Congrats!!! This is great.
Is there any standard to communicate with sensors in the engine? I was actually looking forward to remap my engine. Is there any standards defined? If 'Yes' by which authority/organization it is being done?
Gopi
Gopi
yes u can Remap the Stock ECU fuel maps by over writing the EEPROM, for that u need to remove ur Stock ECU EEPROM or u can do via OBD2 CAN Port by using some sort of Special equipment
Perhaps you could start selling them to the tuning scene as aftermarket ECUs. On some ECUs, the manufacturers lock you out of being able to modify the original map.
If you could incorporate some kind of data logging for race track use, that would be a great feature.
awesome!Congraturation!
Asad, you should really document this a little bit and publish some source files :)
