How to synthesis (VHDL) all GATE level digital circuit?
isaacnewton
Full Member level 2
Earth Village
precision synthesis gate library
I am using Precision Synthesis to do VHDL design. Some time when I do synthesis, it doesn't give all gate level circuit.
Any one knows how to sysnthesis a digital circuit only with gates?
Thank you.
vhdl and gate
what else does the tool give you beside gates level ?
vhdl to gate
This does not happen to me.
-- Exampel - Thee following VHDL code is a simple MUX
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
ENTITY MUX IS
PORT(in0, in1, in2, in3: IN std_logic;
S0, s1: IN std_logic;
z: OUT std_logic);
END ENTITY MUX;
ARCHITECTURE RTL OF MUX IS
BEGIN
z <= in0 WHEN s0 = '0' and s1 = '0' ELSE
in1 WHEN s0 = '0' and s1 = '1' ELSE
in2 WHEN s0 = '1' and s1 = '0' ELSE
in3 WHEN s0 = '1' and s1 = '1' ELSE
'0';
END ARCHITECTURE RTL;
-- The attached is synthesized circuit.
-- Thank you.
It's all gate level ! the right most device is a MUX.
What I want is all INVERTER, NAND, NOR, XNOR ... gate circuit. Is it possible?
Your tool synthesize you code according to the basic library of primitive components. Either select your option or remove the primitive you doesn't like.
I can not find this kind of options. The tool I am using is
Precision Synthesis 2004a.74.
Thank you.
Hi isaacnewton:
You can remove the basic cell you don't wanna from the lib, or you can
set the attribute of that cells to don't use.
wang1
