mequitnever
Junior Member level 1
Hello
I need help with Coplanar strip lines. I have attached the diagram and results with the formula used for the dimensions of the coplanar strips to find Zo, characteristic impedance of the striplines. I used formulas as described in the book by Simons called "Coplanar Waveguide Circuits, components and system". The formula involved elliptical integrals and I used Matlab to solve those formula.
The simulation results in a spike for Z21 (Z paramter between port 1 and port 2) at around 6 Ghz. I do not understand why this spike should appear at that frequency.
Specifications:
Strip length: 20mm
Strip width: 2.8mm
Gap between strips: 0.5mm
Thickness of strip: 0.017mm
material: Copper
Substrate height or thickness: 1.575mm
Substrate relative permittivity: 2.2 (Rogers 4880 Duroid)
Two wave ports at the ends of the strips.
No ground plane
Results:
Using Matlab, Zo, impedance = 130 ohm
Using HFSS version 12: Spike down all the way for for Real part of Z parameter at around 6.15 GHz. Spike down and then up for imaginary part at around the same frequency.
I will appreciate if somebody helps in understanding why this spike appears and what I could do to get the correct results.
Specifications:
Strip length: 20mm
Strip width: 2.8mm
material: Copper
No ground plane
Results:
