AMS simulation with Spectre solver problem - error message
sunil_rpine
ams simulation
I am learning to run a design using AMS simulator with Spectre solver. The set up looked fine and the netlist was generated without any problem. But when I run the simulation, I am getting the following error message:
Failed to elaborate ("amsPLL" "pll_160MHZ_sim" "config").
How can I resolve this. Please help.
Thank you,
Sunil
Re: AMS simulation problem
you have to give some more information. It is diffcult to debug from this much information.
One possible reason can be that during elaboration phase it is looking for some behavioral file which might be deleted or moved. This is just a guess.
Thanks for ur reply. I was actually running AMS for the first time. I found the missing files and it is working fine. But I am yet to get good grip on the AMS simulation using Cadence tools. Can you please give me some references. I am currently going through cadence documentation which is very lengthy and over the top as well.
Thank you,
Sunil
For getting good grip on AMS simulation, the only way out is doing more simulations. there are lot of issues as the tools are not mature enough...........for each of the problems you face raise a query with the tool vendor.........they should solve it........and yes cadence documentation although lengthy but are good enough to start and develop good understangind of tool.....
